genesis startup issue
I due to a virus had no choice but to bring my pc back in time.
so I re-installed daz 4.6 but the start up path for genesis is incorrect.
I selected the path to the dyson file for genesis but this was incorrect.
All of my files are still intact: lib/docs/Daz 3d/studio/my lib/people/genesis
What is the correct path?
  • JaderailJaderail Posts: 0
    the Genesis.DUF for the Start up file.
  • edited December 1969
    i think the new version did not instal correctly.
    lib/docs/Daz 3d/studio/my lib/people/genesis is the path chosen, but warning cannot find Base/genesis.duf
    Though i do have the folder lib/doc/Daz 3d/studio/my lib/data/Daz 3d/Genesis base.
    But no Genesis.duf file.
    I have two seperate lib locations the one i used to use is here
    lib/doc/daz 3d/
    within this struct there is studio, studio 3, studio 4.
    I found quite by accident another file lib/doc/My 3d lib
    This file has all of the .duf and .dsf files
    When tried to point to this location i got the warning again could not find Genesis base.dsf.
    I have Daz studio 3 and can load all my normal content but i need Genesis.
    edited January 2014
    The problem is that Genesis.DSF was changed to Genesis.DUF several versions ago.
    You need to go to Edit > Preferences, and change the name of the startup file from Genesis.DSF to DUF.
    You should still be able to load Genesis yourself from the Content Library, it is only the scene that loads at startup that is causing a problem.
    Post edited by JimmyC_2009 on
    Finally i found genesis male (2) by adding the found quite by accident file lib/doc/My 3d lib to my content directory manager.
    I can load this version
    After a few min the system caught up with the changes and I now can choose either Gen (1) or (2).
    I seem to remember you could search for all content but i forget how to do this.
    Thank you for your kind help
  • TJohnTJohn Posts: 11,430
    Love your new sig image. :)
