animation after rendering issues.
dinosaurmad87dinosaurmad87 Posts: 114
Hi everyone I've just rendered an animation on 1 of my dino models all looks good etc but the issue I'm having when I place the model on 1 of my backdrops in sony vegas platinum the animation seem extremely slow?
Now I did an animation in Daz studio 4 pro going 0 to 60 FPS to 240 FPS ( did animation 0 to 60 FPS til I got to 240 FPS) and played it back after complete and works at a normal pace of speed but once rendered like I said it just moves extremely slowly once placed on backdrop scene?
I rendered it as an Image series to a png file format.
Anybody know the answer to fix this issue?
Chears, Ian. :)
  • Richard HaseltineRichard Haseltine Posts: 111,976
    If it's a PNG sequence then it doesn't contain any FPS information - you will have to set that in Vegas. If you are animating to provide a backdrop to an existing animation then the FPS should match that - if you set it it higher you will get too many frames and the sequence will therefore last too long.
  • JaderailJaderail Posts: 0
    When Rendered to Frames it is up to you to set FPS in the editor program you are using. Many default to a standard 30 FPS but many do not.
  • RuphussRuphuss Posts: 2,631
    Chears, Ian. :)
    you can change speed in sony vegas platinum
    rightclick on your videotrack and change it
