Trouble Loading Genesis Hair in Poser
dbtemdbtem Posts: 30
Hello! I am trying to load Genesis hair models in poser using DSON. The character/figure models load just fine (Aiko for example), but the hair does not. For example, if I try to load "Osaka Hair" onto Aiko, it does not appear. A "skullcap" just appears on her model; though, it lists it as a body part. Alternatively, if I try to use "PH Timeless", the hair appears in the model list, but does not otherwise appear in the viewport even if I instruct it to conform to the base model (Aiko).
I cannot figure out what is going wrong. If anyone could help me, I would greatly appreciate it.
Using:
Poser 2012 SR3.2 (32/64)
Aiko 5
Genesis 2
DSON Importer for Poser (32/64)
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Two things to check: first, make sure that you installed the DSON Core files as well as the PoserCF - the former has the geometry and textures, the latter the Poser library files; second, make sure you are loading the model and not a textures et for the model.
  • dbtemdbtem Posts: 30
    Thank you. Where do I get the Poser Companion Files? I don't remember seeing them listed during the poser installation.
