Help with Layering
I'm attempting to create a storyline that has characters using form fitting scifi armors that have fantasy armors layered on to provide a certain look, but I have to constantly adjust sections whenever I adjust the skeleton. Is there a way to fit the outer layers to the inner?
  • SevrinSevrin Posts: 6,314
    What often works is parenting the outer layer garment to the inner layer garment, rather than to the figure.  You'd right click the outer garment, select change parent, and then select the inner garment from the long, list of options that pops up.
  • Thank You!
