Turn character around
ThomasScThomasSc Posts: 125
edited December 1969 in Poser Discussion
Hi, is there an easy way to have a character walk a straight line, turn around 90 degrees and walk again?
Restrictions:
a) No walk designer.
Problems:
a) If I turn around the whole body, the turn looks awkward.
b) If I turn around the hip, the XYZ axes changes (bending is now twisting).
So, any ideas?
  • TjebTjeb Posts: 507
    Have you tried a .BVH ?
    480 x 270 - 723K
  • ThomasScThomasSc Posts: 125
    Hi,
    Thank you. No. BVH files featuring existing walks are not helpful. I need to create my own walk style.
    Regards,
    Thomas
  • WandWWandW Posts: 2,910
    edited February 2014
    This should get you started....
    http://www.awn.com/vfxworld/poser-7-revealed-create-walk-path
    EDIT: oops; I missed no Walk Designer allowed. You will need to manually animate the hip actor; Walk Designer translates the body actor....
    Post edited by WandW on
