Wow the 4.12 viewport is bad
4.11 was fine, suddenly posing takes FOREVER and everything has to be loaded or something just to move an arm. Where did it all go wrong Daz?
  • LeanaLeana Posts: 13,501
    What graphic card do you have and are the drivers up to date?
    I think a GeForce 1060 and yes they are, just recently.
    Again I think there's a major difference between 4.11 and 4.12
  • PadonePadone Posts: 4,314
    edited October 2019
    It has been noted a slowdown in 4.12 with certain morph packages. It is likely that you use one of them. Don't know if this has been fixed in the latest beta.
    Post edited by Padone on
  • marblemarble Posts: 7,500
    I'm a little at odds with this complaint as I'm finding the opposite. Posing is much smoother and quicker in 4.12 for me so I use the Beta to set up scens and go back to 4.11 to render them (as 4.12 is more than likely to fall back to CPU). I've long grumbled about slow posing response in the viewport in previous versions, especially when fibre hair is present, but 4.12 (Beta) seems - so far -  to be much better.
  • takezo_3001takezo_3001 Posts: 2,041
    This is most likely that you have a few things fitted on your character that has "smoothing" turned on, try turning them off...
  • 4.11 was fine, suddenly posing takes FOREVER and everything has to be loaded or something just to move an arm. Where did it all go wrong Daz?
    I was having a lot of trouble moveing and posing characters, it was real slow and almost kinda jerky. On some of my characters I was using I noticed that they had eye lashes turned on. I turned off the eye lashes and posing was a lot easier. Some times I have noticed turning off the hair while posing helps too.
  • cm152335cm152335 Posts: 421
    i use 1060 3Gb,, no changes in view port and a bit 10% faster render,,
    check F2 preference and use "BEST"
