How to export Genesis as a CR2 file so can use with Mimic Pro
Mosk the ScribeMosk the Scribe Posts: 893
Can anyone explain how to export Genesis as a cr2 file so I can get it to work with Mimic Pro?
(is that possible using the tools available in DAZ Studio 4.6 Pro?
  • TspiritTspirit Posts: 17
    I found this, I think it will help. Hugs Tenderspirit
    https://www.youtube.com/watch?v=XDYEvSb7jQs
  • Mosk the ScribeMosk the Scribe Posts: 893
    Hey Tspirit -
    Watched the video and jotted down a bunch of notes. I'll give it a try in a few days when I have some time. Thanks for the link!
    Hope it works for you. With all the new changes 4.6 rocks but sure is hard to know how to jump back and forth between all the programs. hehe Hugs Tenderspirit
  • invisigothinvisigoth Posts: 155
    hate bust your bubble
    but that video doesn't help
    i have watched it over 20 times..pausing and following step by step
    in the video,there is a box that pops up when you save as cr2 asking where you saved the obj
    in Daz studio 4.6..no box pops up
    i have tried everything..
    and this is what happens when i move a body part
    812 x 778 - 30K
  • Richard HaseltineRichard Haseltine Posts: 110,405
    You aren't meant to pose it, just take it into Mimic to generate a pose for the speech morphs which you then apply to the original figure as I understand it.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,958
    yes indeed my mimic version I saved from Poser has two heads in mimic!!!
    works though
    in the video ,he was posing
    i also get the same results the other way around
    if i take a poser 8 or higher stock character like Alisha2 into daz studio,
    i get a similar problem when posing
    but studio generates a "weight map" warning
  • mmkdazmmkdaz Posts: 335
    Uhhhhhh!! Why is everything so hard with this program!
    Sorry! I over reacted. Hahah! You just have to feed the exporter your runtime location, and a location for the CR2 within libraries/character. And exporter works like a charm!
    Whew, less coffee for me!
    it does not look great in Mimic pro but the exported pz2 Mimic Pose will work fine in Poser or DAZ studio for that matter.
    It also works if you do the same with an exported triax converted Genesis 3 figure.
