Can not apply "Genesis Expressions and face aniblocks" to Genesis female
I just bought "Genesis Expressions and face aniblocks" for Genesis female but could not get it to work.
I see the functions on the aniMate line, i.e. anger, but can not get it to work.
Appreciate any help because without face expresssions the clip is not worth much.
Edit,, if you say about genesis2female,,
(it should work for genesis1 with genesisfemale morph)
I think it can not work for genesis2female. without you tweaking many.
because these expression aniblock need to store each morphs value.
eg, Amazed is PHMAmazed for genesis root. then change the value.
on the other hand genesis2female have not same name morph.
I think it there are same name node for genesis2female,
it may work. but sometimes it cause unexpected effect.
then,,,if you make morph which have same name (PHMAmazed)
for genesis2female,,
it work ^^; (Actually I tried to make morph from genesis2female expression morph,
then save as PHMAmazed,
now I apply the aniblock,,for genesis2female,, it move my morph value^^;)
but I think you better refund the item. it is not for genesis2female.
Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
Is this the one you have : http://www.daz3d.com/genesis-expressions-and-face-aniblocks
It is made for Genesis, NOT Genesis 2, they are different figures.
