[Released] Character Converter from Genesis 8 Male to Genesis 3 Male [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,977
edited November 2019 in Daz PA Commercial Products
Convert your favorite Genesis 8 Male characters to Genesis 3 Male characters! The Character Converter from Genesis 8 Male to Genesis 3 Male transfers the morphs, including JCMs, from the awesome Genesis 8 characters to Genesis 3. The Character Converter scripts provide easy batch execution for automatically converting your Genesis 8 Male Character to a Genesis 3 Male Character in your library. Even better, icons, categories, and the default materials are copied from your original Genesis 8 Male to the new Genesis 3 Male.
The Character Converter scripts outputs are also a merchant resource! If you own the original Genesis 8 morphs, you retain the rights to the converted Genesis 3 morphs to do as you wish.
The Character Converter script is extremely simple to use. Just select the characters to convert and click execute! There is also a Convert Custom Character script which will copy a Genesis 8 Female character in the scene, with all currently used morphs and corrective morphs, to a Genesis 3 Female character (no character preset is created and no materials are copied).
Tutorial on Character Converter Products
Please read the user guide for full details
Features
  • Character Converter from Genesis 8 Male to Genesis 3 Male: (.DSE)
    • Character Converter Script
    • Convert Custom Character Script
    • Detailed user Guide (.PDF)
1000 x 1300 - 465K
1000 x 1300 - 203K
1300 x 1000 - 282K
1300 x 1000 - 210K
2000 x 2363 - 1M
1348 x 1000 - 401K
1600 x 1000 - 598K
1000 x 1300 - 207K
1300 x 1000 - 246K
1300 x 1000 - 165K
1000 x 1300 - 176K
1300 x 1000 - 262K
1300 x 1000 - 205K
1000 x 1300 - 417K
Post edited by RiverSoft Art on
  • And it is released!
  • ArtiniArtini Posts: 10,960
    Nice, wish you many sales of the converter.
    I am still waiting on the converter from V4/M4 -> Genesis 8, though.
    Thanks @Artini!  I hope a V4/M4->G8 converter will happen.
  • wsterdanwsterdan Posts: 3,627
    And it is released!
    And purchased! I love it when everyone does their part. wink
    -- Walt Sterdan
  • wsterdan said:
    And it is released!
    -- Walt Sterdan
    LOL.  Me too! smiley
  • bohemian3bohemian3 Posts: 1,035
    Hiya - RiverSoftArt - Thanks for all the great products you produce - I have used many and find them really useful to the projects I'm working on.
    One quick question - when I convert a character from G8 -> G3, the character comes over great, but I don't get the morph dials and controllers in the shaping tab for the morphs that were transferred over so they are not added into the 'gene pool' for easy combination of existing G3 characters.
    Troubleshooting so far:
    • I do have Show Hidden Properties enabled.  If I export the character via fbx the morphs are avaiable to export.
    • If I search for the morph, the region is properly highlighted but the morph dials do not show.
    Is there something that needs to be done to make them available?
    Again thanks for the great work you do in these products.
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    You're welcome!  If the characters are converting over, then the morphs are there to see.  I would love in a character and then filter on the used properties.  They will show up.
    Hi and thanks for the quick response.  Here is a screenshot.  When I filter on the currently used morphs under Shaping nothing shows up.  Then what's strange is if I search for Sanjay morphs the Head and Body regions highlight but the morphs do not show up.  And insight you have on this is deeply appreciated.
    1866 x 985 - 297K
    Looking at the figure, the Sanjay CTRL is not on.  It looks like the script had a hard time finding the CTRL file to fix it, which means setting CTRL to 1 was not done in the character preset.  I would select top-level Sanjay and filter there.  Also, check your  data/DAZ 3D/Genesis 3/Male/Morph and search for sanjay to make sure the FHM, FBM, and CTRL are there.
  • xyer0xyer0 Posts: 6,518
    Hi! I just bought this on Flash sale (along with its vice versa brother), and I'm wondering if I can convert single morphs (or entire morph kits) as well as characters. What say you?
    Yes, you can.  You would need to use the Custom Scene Character script.  Load in a figure, dial in the morphs you want to convert (they don't need to be 100%, just greater than 0), and convert.
    Thanks so much, and keep up the great work! I certainly wouldn't mind some more modern Now-Crowds, for instance, City Winter and At the Park.
    There are more Now-Crowds coming up in the next month or 2, including modern ones (but not the ones you listed yet)
    Hi RiverSoftArts, I followed the pdf instructions explicitly, but I got an Error Reading File three times in a row (I closed Studio, and started over each time). I was only converting one morph. I used the Custom Character script. Any guidance is appreciated. Here's the log file:
    2020-04-23 22:41:00.846 Loading script: F:/My DAZ 3D Library/scripts/riversoft art/character converter/convert custom character g8m to g3m.dse
    2020-04-23 22:41:00.859 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSConstants.dsa
    2020-04-23 22:41:00.861 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSG8G3CharacterConversionConstants.dsa
    2020-04-23 22:41:00.870 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSBuildPanels.dsa
    2020-04-23 22:41:00.879 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHelperFunctions.dse
    2020-04-23 22:41:00.890 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RS2019HelperFunctions.dse
    2020-04-23 22:41:00.895 DEBUG: Found: F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSG8G3CharacterConversionFunctions.dse
    2020-04-23 22:41:00.908 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2020-04-23 22:46:02.978 DEBUG: DoConvertSceneCharacter Genesis8Male Genesis3Male EJ Genesis 8 Male for Genesis 3 Male EJFM Lower Lip Define 0.05999999865889549 Overwrite Morphs=false Convert JCMs=false Hide Eyes=true Use Legacy Conversion Process=false Convert true
    2020-04-23 22:46:02.978 Converting Character: Genesis 8 Male
    2020-04-23 22:46:02.978 DEBUG: GetUsedMorphs Genesis8Male
    2020-04-23 22:46:04.104 DEBUG: /Actor/Head/Face/Mouth/Real World/EJ Face Morphs/EJFM Lip Lower Definition false
    2020-04-23 22:46:05.005 DEBUG: RemoveExistingMorphs Genesis3Male nameList EJFM Lip Lower Definition overwriteList
    2020-04-23 22:46:05.007 DEBUG: EJFM Lip Lower Definition
    2020-04-23 22:46:05.274 DEBUG: Setting Scale to 1 BEFORE, raw=1, value=1
    2020-04-23 22:46:05.349 DEBUG: Setting Scale to 1 AFTER, raw=1, value=1
    2020-04-23 22:46:05.349 Converting Morphs: EJFM Lip Lower Definition
    2020-04-23 22:46:05.351 DEBUG: Trigger Action DzZeroFigureShapeAction
    2020-04-23 22:46:11.128 DEBUG: Triggered Action DzZeroFigureShapeAction
    2020-04-23 22:46:11.642 DEBUG: Transfer Item, Source is Genesis 8 Male, Target is Genesis 3 Male
    2020-04-23 22:46:11.642 Transferring Morphs from Genesis 8 Male to Genesis 3 Male
    2020-04-23 22:46:11.643 WARNING: Script Error: Line 2514
    2020-04-23 22:46:11.643 WARNING: TypeError: Result of expression 'transfer.setDistanceSquaredTolerance' [undefined] is not a function.
    2020-04-23 22:46:11.643 WARNING: Stack Trace:
    <anonymous>()@F:/My DAZ 3D Library/data/RiverSoft Art/Common/RSG8G3CharacterConversionFunctions.dse:2514
    2020-04-23 22:46:11.659 Error in script execution: F:/My DAZ 3D Library/scripts/riversoft art/character converter/convert custom character g8m to g3m.dse
    2020-04-23 22:46:12.316 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-04-23 22:46:12.316 Loaded file: pJCMShldrUp_90_L.dsf
    2020-04-23 22:46:12.328 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-04-23 22:46:12.328 Loaded file: pJCMShldrUp_90_R.dsf
    Are you using an old version of DS?  The SetDistanceSquaredTolerance function was added in 4.10.0.50.
    Aaah! Thanks. I've been delaying my upgrade, but the time has truly come. Thanks for bothering with this, and sorry for wasting your time.
    No, not at all.  Sorry for pushing you to upgrade smiley
    Upgraded (after some hiccups of the installer not being able to find the file?) and the morph conversion worked EXACTLY as the PDF led me to expect. Thanks for another great product! Now to use your G3toG8 product to get the Genesis 3 Core guys and Slosh's Genesis 2 Legacy into G8M. I'm more of a gardener than anything.
    Awesome!  I am glad it is working now for you.
    I have submitted an update. Hopefully it will be out this week but more likely early next week:
    • Added ability to specify Material Preset option
    • Added ability to detect and load "character" presets
    • Replaced Legacy Conversion checkbox with Conversion Method radio group
    • Fixed Ignore Previously Converted option so that it works
    • Fixed conversion to not allow empty VendorName or ProductName
    • Fixed conversion to not allow Character Name equal to Female or Male
    • Added namespace to all morph safe names
    • Fixed bug for Duplicate Formula Found errors (Adjusting Rigging To Shape would add bones to JCMs)
    • Fixed bug where JCMs/MCMs were not being set as hidden properties
  • AngelikMAngelikM Posts: 114
    edited October 2020
    Hi Riversoft and community.
    I cannot load the script...had installed it through DAZ Central (several times to see if it was a Mercury Retrograde issue wink) but the error continues to appear. Here it is the screenshots https://share.getcloudapp.com/JrugxGZY ;
    Also the pdf file is corrupted ...
    Any suggestions?
    The log file (changed the actual disk name for 'XDisk')regarding this operation:
    2020-10-19 09:50:50.258 File loaded in 0 min 2.1 sec.
    2020-10-19 09:50:50.387 Loaded file: genesis 8 male eyelashes.duf
    2020-10-19 09:50:50.485 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.529 Loaded file: XT_PHMMouthRealismHD.dsf
    2020-10-19 09:50:50.552 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.554 Loaded file: XT_PBMNavel.dsf
    2020-10-19 09:50:50.603 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.605 Loaded file: PHM-BriarHead-LLF.dsf
    2020-10-19 09:50:50.617 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.619 Loaded file: LLF-BriarEyes.dsf
    2020-10-19 09:50:50.667 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.669 Loaded file: FBM-BriarBody-LLF.dsf
    2020-10-19 09:50:50.788 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.790 Loaded file: PHM-BriarHead-LLF.dsf
    2020-10-19 09:50:50.796 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.804 Loaded file: FBM-BriarBody-LLF.dsf
    2020-10-19 09:50:50.805 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:50:50.806 Loaded file: PHMEyelashesExpand.dsf
    2020-10-19 09:50:51.485 File loaded in 0 min 0.3 sec.
    2020-10-19 09:50:51.489 Loaded file: base mat eyelashes.duf
    2020-10-19 09:50:57.535 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-10-19 09:51:01.931 File loaded in 0 min 10.2 sec.
    2020-10-19 09:51:01.935 Loaded file: briar necksmoother.duf
    2020-10-19 09:51:01.945 DEBUG: Failed to load addon
    2020-10-19 09:51:03.193 File loaded in 0 min 0.8 sec.
    2020-10-19 09:51:03.197 Loaded file: briar nose.duf
    2020-10-19 09:51:03.213 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:51:03.217 Loaded file: PHM-BriarHead-LLF.dsf
    2020-10-19 09:51:03.277 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-10-19 09:51:03.294 Loaded file: FBM-BriarBody-LLF.dsf
    2020-10-19 09:51:03.309 DEBUG: Failed to load addon
    2020-10-19 09:51:03.602 Finished Loading Character Addons
    2020-10-19 09:51:03.751 File loaded in 0 min 52.0 sec.
    2020-10-19 09:51:03.757 Loaded file: briar (llf).duf
    2020-10-19 09:51:15.105 Loaded image llf-briarbase-torsofreckles.jpg
    2020-10-19 09:51:16.552 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d2.png
    2020-10-19 09:51:16.717 Loaded image llf-briarbase-headfreckles-nobrow.jpg
    2020-10-19 09:51:17.023 Loaded image llf-briarbase-headeyebrows.jpg
    2020-10-19 09:51:18.256 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d3.png
    2020-10-19 09:51:18.500 Loaded image llf-briarbase-teeth.jpg
    2020-10-19 09:51:19.242 Saved image: /Volumes/Xdisk/Application Support/DAZ 3D/Studio4/temp/d4.png
    2020-10-19 09:51:19.465 Loaded image llf-briarbase-armsfreckles.jpg
    2020-10-19 09:51:20.716 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d5.png
    2020-10-19 09:51:20.944 Loaded image llf-briarbase-legsfreckles.jpg
    2020-10-19 09:51:22.040 Saved image: /Volumes/Xdisk/Application Support/DAZ 3D/Studio4/temp/d6.png
    2020-10-19 09:51:22.172 Loaded image llf-briarbase-torsofreckles.jpg
    2020-10-19 09:51:23.364 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d7.png
    2020-10-19 09:51:24.675 Loaded image llf-briarbase-torsofreckles.jpg
    2020-10-19 09:51:25.022 Loaded image llf-briarbase-headfreckles-nobrow.jpg
    2020-10-19 09:51:25.100 Loaded image llf-briarbase-legsfreckles.jpg
    2020-10-19 09:51:25.219 Loaded image briar_eye_3.jpg
    2020-10-19 09:51:25.315 Loaded image llf-briarbase-armsfreckles.jpg
    2020-10-19 09:51:25.421 Loaded image llf-briarbase-teeth.jpg
    2020-10-19 09:51:25.612 Loaded image g8mbaseeyelashesmaptr_1006.jpg
    2020-10-19 09:52:20.947 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-10-19 09:53:15.313 Loading script: /Volumes/Xdisk/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/scripts/riversoft art/character converter/character converter g8m to g3m.dse
    2020-10-19 09:53:15.314 Failed to load script: /Volumes/Xdisk/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/scripts/riversoft art/character converter/character converter g8m to g3m.dse
    2020-10-19 09:54:12.493 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    Lots of sunshine.
    Thanks in advance.
    466 x 304 - 14K
    1094 x 824 - 404K
    1134 x 732 - 394K
    Post edited by AngelikM on
    Any suggestions?
    Lots of sunshine.
    Thanks in advance.
    It's definitely not installed properly.  The icons do not even show up.   Do the files even exist in that location?
    Hi Riversoft... uninstalled and reinstalled them and still doesn't work... is it fixable, please?
    I am sure it is fixable.  Unfortunately, it is hard to debug installation problems, especially remotely. sad  What does the Daz log say now?  Did you try uninstalling, verify NO files are left in the Daz Connect area, and reinstalling using DIM?
