Sharing Morph Slider Dial Files
Using Shape Shift for G3 by Zev0 I created some body morphs and saved master slider dials (new property, ERC freeze, save morph asset method) and want to share the master slider dials (for anyone that owns Shape Shift for G3).
Are any other files required other than the saved .dsf files created when saving the master slider dials?
Thanks!
Post edited by surrender dolls on
    edited October 2019
    Licensed? If not you would have to separate out your morphs from any of Zev0s morphs before redistributing your own work.
    If all what you did was use Zev0s dials, then what would be saved out are not new morphs but a shaping preset file if I recall correctly. Information which would simply set any of those dials to the desired readings.
    If what you did was a combination, then you save out "your own work" as morphs and can have them attenuate the required morphs from Zev0s set. Or make a combination of your morphs plus pose settings for Zev0's morphs.
    n.b. I'm not a license expert, contact the Company if needing clarification on that, it's not being sold as MR.
    Post edited by Catherine3678ab on
  • surrender dollssurrender dolls Posts: 20
    edited October 2019
    Thanks for the info Catherine3678ab
    I only used Shape Shift morphs to create a master slider dial that sets the Shape Shift morphs to the desired value. Basically I created some body type morphs, saved a slider dial and am wondering how someone else could load up one of these slider dials that when used set Shape Shift morphs to the settings I used when I created the slider.
    Aa a test I copied one of these moprh .dsf files I saved and renamed it, loaded up Daz, but the renamed slider doesn't show in Daz Paramaters like the other morphs I created so I know there must be another step or file I need.
    Any info is appreciated.
