Trouble Resetting Pose
Anki
Hi there,
I have a problem with the pose reset on a particular figure. The model is gen 8, with a lot of morphs and a loaded pose.
I use the "Edit > Figure > Zero > Zero Figure Pose" action.
The figure resets but to a wrong zero pose. For example, the feet are close together (even touching) instead of appart.
Is there a way to truly Zero or Restore the pose the the original setting ? Is is my model doomed ?
Thanks
Post edited by Anki on
Check the Currently Used group in the parameters pane - Zero Figure Pose works only on properties that have their type set to Modifier/Pose - if there is a pose control in use that is not correctly set then it will have been left alone.
Solved it. ^^
For those of you getting the same issue :
The pose was reset to default position, so that wasn't the problem. My problem was that I had previously loaded a pose that also affected the parameters for some reason. I looked at every bone of my model and found the left and right thigh bends had side-side set to 11 and -11. So I set them back to zero manually.
All fixed ! Don't trust loadable pose sets, lesson learned.
We commented at the same time. You're right, the problem was in the parameters pane. :)
