Eva 8 HD Add-on
bjoernb78
Hi there,
while I can load the hd version of any figure by clicking the hd icon, Eva 8 comes in all grey. So I need to search for materials and load her maps.
As I only have this work around with Eva 8, my question is, if this is the meant workflow for it, or did I just miss anything to download or else?
If I do everything right, is there a chance that this product gets an update, so it works with a simple one-click solution like all the others?
Thanks!
You can just find the slider (Eva 8 HD, I think, in this case) in the Shaping or parameters panes and set it there - the HD is not separate figure, it just loads he figure with the HD morphs applied.
At leastbetter than my solution. Thanks!
@bjoernb78
If you are going to change eye colors, add makeup, etc you will still need to go to the Materials folder. I don't see why this is an issue. Even your "one click" solution requires going to the Materials folder to do anything else.
