How to package two prop into one
Hi i try to make some freebies and i have problem to pack them.
Normally i take my prop and save it as support asset --> figure /prop assets and the job is done. But i have a nightstand and for commodity i parent it a drawer as another prop and just set the z translate slider to open it.
So when i want to save it i have two separate prop but i want to save them as one.
Is it possible to do it? or do i have to combine them before saving and rig the drawer to open it.
Thanks for reply
  • LeanaLeana Posts: 13,288
    edited October 2019
    IIRC you can save them together as a Scene asset.
    Post edited by Leana on
  • macleanmaclean Posts: 2,438
    First, save them separately as assets (what you've been doing). That creates a data folder for each prop. Then parent the drawer to the nightstand (drag it onto it in the Scene pane), and save them together as a Scene Subset. You'll get a dialog with the prop names and if you expand it, you'll see them both checked. If there's anything else in the scene - lights, cameras, etc - it'll also be saved, so make sure you uncheck anything you don't want.
