moving content (1 harddrive to another), need help
assmonkeyassmonkey Posts: 0
It gives me issues if I move the content
They're on 1 called a F drive, then I want to move them to another drive, I drive
When I do, and open it, it'll give me a bunch of missing errors (errors of linked morphs, ect)
How can I move content form 1 drive to another without getting errors anymore?
    After you move the folders you need to remove the old location and add the new one to your content libraries in DS.
    Edit > Preferances > Content Library > Content Directory Manager.
    Add the folder as both a DS and Poser format folder.
  • fixmypcmikefixmypcmike Posts: 19,707
    If you use custom categories, export user data. After you've moved the content and changed the paths in Content Directory Manager, reset the database and re-import metadata to correct all the references to the new path.
  • assmonkeyassmonkey Posts: 0
    Thank you
    I just edited the older location (from the F) to the I version...seeing as I had a harder time adding it
    Works now
