what is the Resolution for GenX?
assmonkeyassmonkey Posts: 0
Yeah, as the titles
I see something called Resolution, and it's default is at 10...just not sure what it does...or what's it for
  • Angel_2232633Angel_2232633 Posts: 1,204
    edited March 2015
    The transfer resolution in the options determines the
    density of these magnets. Lower values preserve more details, but too low values may cause errors
    because some points are not transferred at all. (You will get a warning in that case.) Larger values
    give smoother results but may cause a loss of detail. The effect of this option also depends on the
    mesh density where the morph is applied. If you are not sure, simply use the default value.
    Post edited by Angel_2232633 on
