DAZ Studio Environment Shaders, DS3 or DS4+ ?
srieschsriesch Posts: 4,243
Does anybody know if these two 3DL shaders only work in DS3, or if they will work in DS4 and up?
DAZ Studio Environment Shaders: https://www.daz3d.com/daz-studio-environment-shaders
DAZ Studio Environment Shaders 2: https://www.daz3d.com/daz-studio-environment-shaders-2
  • SimonJMSimonJM Posts: 6,102
    They are 3Delight shaders, so as long as you use 3Delight for render engine they should work in any version of Daz Studio.
  • srieschsriesch Posts: 4,243
    I know that there are a number of VERY old 3DL shaders that no longer work, unfortunately (all the Bryce conversion ones for example, and I thought I ran into some more recent ones with an issue as well but can't remember for sure).  I'm trying to determine if these two are before or after that cutoff line.
  • scorpioscorpio Posts: 8,533
    I think these may be some that don't work in anything above DS 3, I may be wrong and they were updated at some point. If they don't work you can always return them.
  • fixmypcmikefixmypcmike Posts: 19,735
    They're texture-based, so the textures work, but I haven't looked into whether they work fully.
  • Charlie JudgeCharlie Judge Posts: 13,659
    edited May 2020
    They work in DS 4.12 and even work with iray. Here is a quick Iray render of the Earth environment shader applied to a primitive sphere
    1130 x 866 - 434K
    Post edited by Charlie Judge on
    Thanks!
