For Other Blender Users: Quantized Artifacts On Displacement
SickleYieldSickleYield Posts: 7,651
(I haven't found a Blender subforum, so I put it here. I apologize if this is the wrong place.)
Okay, I'm at my wits' end with this and neither the blender forums nor the wiki nor Google seems helpful. I'm trying to help a friend establish a workflow for generating displacement directly from Blender 2.69 (I now use Zbrush, but I wouldn't mind having this option, too).
Our problem is that the generated displacement map is unacceptable for commercial use because of repeating square artifacts on it, with size of artifact being proportional inversely to the number of faces in the base resolution (cube gets big artifacts, shirt gets small artifacts). A pic is attached.
So far the workflow I"m going on is this:
Import or build UV-mapped obj. Check normals are facing out properly.
Add multiresolution modifier. Increase to 5.
Sculpt at 5.
Turn preview down to 1.
Go to UV/IMage editor in Edit mode and add the plain black image with 32 bit float.
In Object mode, go to the Bake panel and choose Displacement, using the "bake from multires" and 'low resolution" options with a margin of 16.
Bake.
I get a displacement map, but it's not usable because of repeating square artifacts in the final displacement map. This is replicable across different blend files and even starting from sculpting a cube or a flat plain. Can I get rid of this, or is it back to baking to normal map and decomposing to channels to get displacement that way?
912 x 993 - 102K
Post edited by SickleYield on
    Hmmm...I haven't tried baking displacement maps in Blender, so I'm not going to be much help, but which version/build of Blender?
    Version 2.69.
    edited January 2014
    I've still got 2.64 installed...I was planning on updating soon, so I'll check it out after I do.
    In 2.64, I get it too, if I have Low Resolution enabled, but if I don't it puts out a nice smooth map.
    Post edited by mjc1016 on
    edited January 2014
    yes,, in 2.69 when I check off Low resolution mesh,under bake button in Render property ,
    it seems bake smooth displacement map.
    if I chedk on it, I find grid in baked texture too.
    1011 x 808 - 132K
    942 x 834 - 135K
    Post edited by kitakoredaz on
