Is there any way to render only an emission without the object itself? Please, read above...
Well, I have a plane that has an emission material, I just wanna hide the plane and stay with its emissive effect... Any idea? Thank you!
1938 x 846 - 553K
  • zombietaggerungzombietaggerung Posts: 3,943
    edited October 2019
    In the surface settings set the Cut Out Opacity to .0001, it will still give light but be invisible.
    Post edited by zombietaggerung on
  • In the surface settings set the Cut Out Opacity to .0001, it will still give light but be invisible.
    Nice tip Zombie, however, I must brutaly increase the emission luminence to see the effect. A great tip, off course. Any other suggestion?
    1722 x 878 - 581K
  • why not move the plane out of the shot and adjust the light output as needed?
  • The first image uses Texture Shaded view, and either has the headlamp on or Preview Lights off, the second is an Iray preview with no headlamp - they would not be expected to match. At the very least you will need to adjust Tone mapping from the default values.
