Saved Render Icons
in New Users
Daz apparently creates a tiny 'icon' image in the renders save folder to go along with each rendered image saved there, which is incredibly annoying if you want to browse through your images. Even more obnoxious, if you delete them, it just creates them again. Is there any way to get it to stop doing this or do I just have to go in manually and move my rendered images into another folder every time I save them?
If you use the button at the bottom of the render pane to select Folder instead of Render Library then you can specify a location DS doesn't monitor and just save normally, without the thumbnails. You can also use File>Save Last Render to save to a location not in the Render Library.
