dForce Hair loads large grey block over character head.
Having issues with dForce Side Bob Hair. When I load it onto the character I get a large grey block over their head.
Under View Log File it says this.
2019-10-16 13:34:29.908 Loaded Morph Deltas in 0 min 0.0 sec.
2019-10-16 13:34:29.909 Loaded file: JCM_ChRO_HeadBendFront.dsf
2019-10-16 13:34:29.922 Loaded Morph Deltas in 0 min 0.0 sec.
2019-10-16 13:34:29.922 Loaded file: pJCMHeadFwd_25.dsf
2019-10-16 13:39:13.103 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.109 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.115 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.120 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.125 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.130 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.134 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.140 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.141 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.146 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.147 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.191 JSON interpreter warning: Unexpected member object: polyline_list
2019-10-16 13:39:13.203 JSON interpreter warning: Unexpected boolean member: disable_morph_projection
2019-10-16 13:39:13.203 JSON interpreter warning: Unexpected boolean member: consider_lines_as_rigid
2019-10-16 13:39:13.203 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.209 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.210 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.215 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.216 JSON interpreter warning: Unexpected numeric member: version
2019-10-16 13:39:13.216 JSON interpreter warning: Unexpected string member: hair_simulation_info
2019-10-16 13:39:13.264 WARNING: fileinput\dzassetdaz.cpp(11073): UV set: "/data/Linday/dForce%20Side%20Bob%20Hair/dForce%20Side%20Bob%20Hair%20Base/UV%20Sets/Linday/Base/default.dsf#default" has wrong vertex/facet count
2019-10-16 13:39:13.264 WARNING: fileinput\dzassetdaz.cpp(1910): Could not find UVs for geometry.
2019-10-16 13:39:13.264 WARNING: fileinput\dzassetdaz.cpp(1349): Failed to create uv set!
2019-10-16 13:39:13.267 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.273 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.273 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.279 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.279 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.284 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.284 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.289 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.289 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.293 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.293 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.294 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-16 13:39:13.294 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-16 13:39:13.300 WARNING: fileinput\dzassetdaz.cpp(5359): Failed to create user property instance.
2019-10-16 13:39:13.300 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Hair Follow!
2019-10-16 13:39:13.300 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Hair Generator!
2019-10-16 13:39:13.305 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Render Hair Generator!
2019-10-16 13:39:13.305 WARNING: fileinput\dzassetdaz.cpp(5359): Failed to create user property instance.
2019-10-16 13:39:13.305 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: Line Tessellation!
2019-10-16 13:39:13.314 File loaded in 0 min 0.2 sec.
2019-10-16 13:39:13.314 Loaded file: 01. dForce Side Bob Hair.duf
2019-10-16 13:39:13.485 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
2019-10-16 13:39:13.497 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()
Can anyone make sense of this?
All the "dforce" hairs Require DS 4.11 or higher, they don't work in earlier versions.
Are you using DS 4.11 or 4.12? Earlier versions will not use dForce hair (there are products that use the dForce Cloth for hair, and those do work in older versions of DS).
Yea I found that after posting. It now works after updating but I can only render via my CPU it won't render via the GPU now, tried reinstalling Graphics Card drivers (as that helped last time I updated Daz) but still not rendering...
You need a driver version of 430.86 or later for the version of Iray in DS 4.12
I tried updating the drivers via Device Manager, then I restarted. Still not working. I tried downloading drivers from their site but they would not install kept giving me an error that the driver was not compatible with my operating system. I'm using a fairly old GTX 460 GPU the latest driver for this graphics card I can find on Nivida is March 2018... so am I screwed?
Alright, well I just rolled back to 4.10, this appears to be affecting a lot of people so maybe Daz will get around to addressing it. Dforce isn't worth it for this. When Daz says your GPU is supported one would assume all features should work. Think I'll just stay away from dforce.
If anyone knows of a hair that looks like this but isn't dforce please let me know: https://www.daz3d.com/dforce-side-bob-hair-for-genesis-8-females
I'm pretty sure that the 480 would not be supported by Iray even if yiu could get an updated driver. nVidia gradually phases out older models as they update Iray to newer versions.
