Can you change the order of morphs?
RKane_1RKane_1 Posts: 3,039
Can you change the order of Morphs in a group of Morphs?
I want to rearrange the order of a group of morphs to make more sense and make for a better flow of a product. Is it possible to change the order?
  • Richard HaseltineRichard Haseltine Posts: 111,223
    Only by renaming them, or creating new groups. Within a group morphs are sorted alphabetically.
  • RKane_1RKane_1 Posts: 3,039
    By Label or Name.... neither seems to be working. Probably user error.
    edited January 2014
    Are the morphs you are trying to reorder part of the same group?
    Edit: OK, that doesn't work - I suspect the order may be fixed after loading, in which case you'd need to test by saving a couple of renamed morphs and then reloading the figure if it's worth pursuing.
    Well... crap. :(
    Anyone else?
    Okay... oddly enough, the alphabetization thing went into effect AFTER I saved it and reopened it so, problem solved and it alphabetizes by Label, not Name.
    Thanks for yourt help, Richard. As always, I appreciate your assistance and appreciate your willingness to help all comers. :)
    That makes sense...sort of...all of that is loaded into memory when you start Studio and doesn't seem to refresh when you make changes...just when you add things (like a new morph by way of Morph Loader...). So restarting will load the 'new' order.
    Not sure if that qualifies as a bug or an oversight...but I think an autorefresh in this area would be very useful.
    edited January 2014
    I agree. I would also like to be able to drag and drop files to arrange them.
    Being able to program the same repetitive task of Adjust Rigging to Fit and ERC Freeze all rolled into one command when you go to save your morph.
    Making an "Update Morph: option from the pull-down menu in Edit Mode. (Love Edit Mode)
    Also, having addition buttons by the morph that would allow me to auto-zero out any individual morph would be nice.
    And a Zero Scale parameters that would make all Scale parameters 100% would be nice too.
    Post edited by RKane_1 on
