Oso Pookafur and the dreaded gray block issue
I just picked up the Oso Pooka on sale, but upon installing it via DIM and trying to load the Pookafur geoshell (with or without a Pooka model loaded), it comes up as the infamous gray blocks.  What's more, the Surfaces tab shows absolutely nothing.  I've checked the data path to confirm that things where they should be, tried uninstalling/reinstalling via DIM again, tried installing manually...nothing's working.  The log file provided some interesting information:
2019-10-15 22:22:09.219 WARNING: fileinput\dzassetdaz.cpp(4667): Could not find node parent.
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(11073): UV set: "/data/Oso3D/Pooka/Pookafur/UV%20Sets/Oso3D/Base/default.dsf#default" has wrong vertex/facet count
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1910): Could not find UVs for geometry.
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1349): Failed to create uv set!
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(5359): Failed to create user property instance.
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Hair Follow!
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Hair Generator!
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: dForce Render Hair Generator!
2019-10-15 22:22:09.250 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: Line Tessellation!
2019-10-15 22:22:09.250 File loaded in 0 min 0.3 sec.
2019-10-15 22:22:09.250 Loaded file: Pookafur.duf
So what am I missing here?
  • LeanaLeana Posts: 13,502
    Which version of DS do you use? This is dForce hair so you need at least 4.11, and the latest update to dForce essentials.
  • I was still on 4.10 because I have the IQ of wallpaper paste.  I've just updated to 4.12 and, wonder of wonders, now the fur doesn't look like wombat poo.  Thank you for the gentle reminder to not be blatantly dumb.  :)
