Long character load times........Always!
Any character I load, takes forever to load (like 15+ minutes) and when base genesis character models load in they have all kinds of morphs applied already. The morphs make them look like hideous elves. The only thing I can think of is that the morphs that are being applied is what is causing these long load times. And even zeroing the models out takes like 10-15 minutes. So just loading a single character can take anywhere from 30 minutes to an hour. I do have a rather large library or characters and morphs and I have had issues with the Big Girl morphs causing issues. But even the base Genesis models need to be zeroed out before I can use them because of the applied morphs at load. Is there a way to load a model without morphs?
I am attaching a picture of a base genesis 8 female model after loading before I zero it out. Hopefully someone has had this issue and can help because I am at a loss.
I am also attaching a screenshot of my hardware specs so anyone helping knows what I am working with. I don't think it's my system.
One or more morphs has a non-zero default value, you need to identify the culprits (look for properties in the Currently Used group in the Parameters pane which have greyed-out values) and either unisntall the content, and ask for it to be fixed, or adjust the default value and resave (perhaps, to be safe, removing the original fiel first) - you can adjust the default value by clicking the gear icon on the slider and selecting Parameter Settings.
Thank you for the response. I found around 30 morphs in currently used after loading the base genesis 8 model. I have removed them all from my library and now I am back to loading models in under a minute. You are a life saver. Thank you so much!
