Required package versions
If a product requires Aiko 4 and I have Aiko 7 will that meet the requirement?
I'm guessing not but figured to ask.
  • LeanaLeana Posts: 13,548
    No. If a product requires Aiko 4 it means it has been made for Victoria 4, which is a totally different figure from G3F, the base for Aiko 7. Depending on what the product is there might be a way to use it on G3F, but out of the box it won't work.
    Is there a specific product you're interested in?
  • AabacusAabacus Posts: 407
    https://www.daz3d.com/warrior-maidens-bundle
    Yeah, I figured. Sad trombone.
    This package needs the girl 4 and Aiko 4 for some of the models.
    not an emergency. Just trying to fill a gap. Thanks though!
    Those are characters for Victoria 4.
    It's possible to convert them if you are interested in using then on G3F or G8F but you'll need several tools for that, and quite a bit of work:
    • You can use the textures on G3F or G8F if you have Cayman Studios' Legacy UVs V4 product (the G3F version is at Rendo, the G8F one in the store here).
    • For the morphs you could convert them to G3F if you have GenX2 and its G2 and G3 add-ons. There's no G8 add-on as the creator sadly passed away a few years ago, but there's a character converter from G3F to G8F. You will need the required products though if you want to convert the morphs, otherwise you won't have the full character converted.
    Be aware that the characters won't have Iray materials, or even DS materials at all for Tazi and Okami. There used to be free 3DL materials for them available long ago, but I'm not sure they still are available somewhere. So you will need to adjust the materials.
    Hey! Such a kind write up! Thank you! I'll check out those tools! Honestly, I'm just doing some throw away renders for my D&D group so I'm $30 interested in having more options but not all the time it might require to jigger it all together (instead i'll use my time shopping in the store...*sigh*). Still, would be good tools to have so I'll check them out! Thanks again!
