Question about multi renders
MilosGulanMilosGulan Posts: 1,993
Is there a way in Daz Studio to make 14 renders of different custom sizes at the same time?
For now i know only to make individual custom sized renders and i need to do it 14 times. I can't just resize them because of the transparent background which doesn't look good after resizing.
  • Richard HaseltineRichard Haseltine Posts: 111,972
    If they are the same settings that you need to reuse on different scenes then save a render preset for each - File>Save as>Render preset - then you can set your scene up, open the Content Library to the folder you saved the presets to and just click through them and render each. If you do it a lot it may be worth learning to script so that you can fully automate the process.
  • TjebTjeb Posts: 507
    If you will be doing so more often, consider buying this:
    http://www.daz3d.com/other-resources/batch-render-for-daz-studio-4-and-rib
  • MilosGulanMilosGulan Posts: 1,993
    Thanks for your answers, that seems like a thing i need.
