Truespace into Carrara import; 'Ghost' / 'X-Ray' effect
DavidB
I know this is a pretty unusual combination of programs, but I've only in the last couple of months found out how active the Truespace community still is.
Truespace objects - .COB files - import very easily and quickly into Carrara. Textures are different; there are more general questions about importing textures from TS but there's a particular effect which I'd like to get rid of.
If transparency is enabled in Carrara the TS imported model has several parts of itself which are semi-transparent. Disable it and the problem goes but there aren't many scenes which won't need transparency.
I've attached two images which show you what happens. Does anyone have any any suggestions? Thanks.
800 x 600 - 36K
800 x 600 - 33K
Post edited by DavidB on
it might be type of alpha channel in the texture file
