Do Daz female characters never bend over?
That's not meant to be click bait; I mean it! I have gone through so many pose packages trying to find natural looking poses for G3 females simply bending a bit to lean on a railing or a chair back (or, like, whatever), either with their forearms folded on top of the [fill in leaned-on item here], or with their arms outstretched and their hands gripping a railing (as in a balcony railing), and its as though nobody in the Daz universe ever heard of such a thing.
I'm so frustrated. And I know, I know, I can probably "create" the pose manually in 1/4 the time I've already spent hoping and expecting to find one. I'm so burnt out, though, at the moment, with manually making poses for animations I'm praying that somebody here knows of some pose package I haven't found yet, and can make make a suggestion. I'm throwing in the towel tonight. If anybody has any practical suggestions that can help me over this latest hump, I would be very grateful indeed.
  • vwranglervwrangler Posts: 5,001
    edited October 2019
    What you want is specific enough and niche enough that, no, it probably doesn't really exist in the form you want. You'll need to adapt vaguely related poses to your purpose.
    https://www.daz3d.com/z-utility-bending-down-poses-and-partials-for-genesis-3-and-8
    https://www.daz3d.com/z-utility-kneel-sit-crouch-poses-for-genesis-3-and-8
    https://www.daz3d.com/z-push-pull-and-carry-utility-poses-for-genesis-3-and-8
    https://www.daz3d.com/i13-on-the-rails
    Post edited by vwrangler on
  • What you want can be done with a modeler you need to take the model into the modeler of your choice and make sure you don't change any polygons just move them. Then bring your results back into daz via morph loader pro and then when you pose your character those morphs will be available for you to make the model look more natural. Or you can buy the ones that are offered but the selection is limited and does not cover every pose or situation.
  • mavantemavante Posts: 734
    vwrangler said:
    Good land! I think i13's "On the Rails" may be exactly what I need—or at least will get me close enough that I can tweak something from there. I never in the world would have guessed to search for "rails." So thank you, thank you, thank you!
    What you want can be done with a modeler you need to take the model into the modeler of your choice ...
    Thanks, Silver Dolphin, but the "modeler of my choice" is "none." frown blush
    Seriously, I really do have to count on mostly off-the-shelf models for the kind of thing I do (well, I have done a little kitbashing here and there). And I think vwrangler has provided what looks like a solution to this thing I'm currently confronted with.
    It make get this project back—well, back "on the rails," so to speak.
  • MasterstrokeMasterstroke Posts: 2,372
    What about " un-hollow back" magnets? A single magnet should just do it.
    I have no idea what you mean. The "On the Rails" poses are working for what I needed.
  • p0rtp0rt Posts: 217
    edited October 2019
    turn the parameter limit's off in the menu on the top left of the pane, then you can do this
    Post edited by Chohole on
  • ParadigmParadigm Posts: 425
    I find almost all poses for both male and female to be modelling poses. Pretty uncommon to find decent every day poses.
    Yep. The majority of them I see, I think: Nobody I've ever known stood like that even once. :) They have that, "Look at me, I'm posing" look in so many cases.
    There are a few exceptions, for which I am grateful.
  • marblemarble Posts: 7,500
    edited October 2019
    I tend to use the pose sets I've purchased as starters or approximations. I then tweak them until they look natural for the activity in which they are supposed to be involved.
    Post edited by marble on
  • MattymanxMattymanx Posts: 7,000
    If you are still looking for everyday type poses for G3, may I suggest my own?
    https://www.daz3d.com/everyday-poses-for-genesis-3-and-8
    https://www.daz3d.com/various-poses-4-for-genesis-3-and-8-female
    Cool, I just added these to my cart. Nice poses, Mattymanx!
    The Z Utility Kneel Sit Crouch Poses is a nice set. I use them from time to time as starting poses. It's too bad those rail poses are for the G2/G3 ladies. Otherwise I'd be grabbing those now as well.
  • L'AdairL'Adair Posts: 9,479
    I use G3 poses on G8 and vice-versa. There are several scripts available with other products that will convert the arms and legs easily, even some free scripts, but it's easy enough to do manually, too.
    • G3 pose for G8
      • Left Thigh Bend, Side-Side: +6.00
      • Right Thigh Bend, Side-Side: -6.00
      • Left Shoulder Bend, Bend: -45.50
      • Right Shoulder Bend, Bend: +45.50
    • G8 pose for G3
      • Left Thigh Bend, Side-Side: -6.00
      • Right Thigh Bend, Side-Side: +6.00
      • Left Shoulder Bend, Bend: +45.50
      • Right Shoulder Bend, Bend: -45.50
    The shoulder bend is approximate. I've seen different values recommended, but all somewhere between 45 and 46. Take advantage of Daz Studio's math capabilities: Highlight the value to change, move the cursor to the far right of the value, type in the operator, (+ or - for these,) followed by the values above. Then tweak as usual.
    Yes, thanks, Mattymanx, yours are definitely among the "few exceptions" I mentioned. It's obvious that you took great care to breathe humanizing life into all of your poses, and I applaud you!
    L'Adair said:
    • G3 pose for G8
    • G8 pose for G3
    Thanks for that! Great info to have.
    Thank you both and you're welcome to both of you! smiley
  • RobinsonRobinson Posts: 751
    Whenever limits are turned off, it usually means I'm going to have to make a correction morph at some point (the deformations are mostly not volume preserving, so tend to look unnatural - I suspect you've hidden a sin or two with the camera angle!).
  • w00tusw00tus Posts: 20
    They're not those kind of gals.
  • pctech4nypctech4ny Posts: 184
    mavante said:
    This new set for G8F might be of some use; it has a bunch of leaning and sitting poses intended to be less "pinup style."
    https://www.daz3d.com/ff-insouciant-beauty-poses-for-genesis-8-female
    Very nice too. No bend-from-the-hip poses but some useful and different ones nevertheless. I have quite a few sets from FeralFey - all used often.
