white skin render
My renders and quick renders are coming out white . i seen previeous posts from 2017 and 2015 that mentions the temp folder and brickyard but i dont have anything called brickyard anywhere around my daz files . I have tried saving my scene  , closing daz and reopening the scene  . Not to mention  reloading a new character before doing anything to render settings and character editing  and it still renders out the same way . PLEASE HELP
    We're going to need to know a bit more, and some screenshots would help.
    1. Are you rendering in Iray or 3Delight?
    2. What figure/character are you using?
    3. What are you using for the lighting?
    4. Are you using a camera or just the default perspective view in the viewport to render from?
    Screenshots of render settings and surface settings on the figure might help too.
  • Faeryl WomynFaeryl Womyn Posts: 3,792
    I have had this happen a few times as well, from what I can tell in my experience, it's the difference between rendering in iray or 3dl, the other possible culprit is the textures themselves, when I put a different texture on I don't get the all white skin.
    I definitely would like to know what is causing this.
  • cm152335cm152335 Posts: 421
    i had the problem in older daz version
    when brickyard fail,
    delete it manualy in temp folder, that create new in next render,,
