create custom action and the script menu
anyone know why most scripts in 4.11/4.12 won't work if they don't have an icon, they all used to work in 4.10
or anyone know who to fix the scripts which do not work.. when they are selected on the script menu
  • The code may have changed in main program. I would contact the creator of script and see if they can update it.
  • p0rtp0rt Posts: 217
    I can't see mcasual updating every script that is up for download
  • If they had an icon and now don't that sounds to me as if the files have been moved or corrupted.
    there might be a .png in the scripts folder, but when you create a custom action, the .png isn't used on some scripts for the menu icon, then those do not work when selected on the menu, even though they did in 4.10
  • HatBHatB Posts: 79
    Is there a way to delete custom action script so it can be reinstalled? I have Super Save and cannot use the overwrite where it uses the Invida unless I use the increase number. It tells me it is installed but doesn't work. Previously I could change the workspace choice and then reinstall it, but now it just says it is there and doesn't do anything.
    edited November 2019
    press F3, and delete the custom action, or in the right pane, click on the menus tab, and open the main menu bar list, and then open the &scripts list, to organise custom actions into categories, which you can type when you create a custom action in 4.11+
    Post edited by p0rt on
    Thank you so much. I found a bunch of scripts I had done prevviously and some had duplicates.
