how do you set up custom uvs for DS droplist? pacifically the mildragons
MistaraMistara Posts: 38,675
can the uvs add mat zones too?
if i use uvmapper classic to export a uvs set, is it ready to set up for the DS uvs dropdown list?
anyway to transfer the mat zones from a uvmapperclassic saved .obj to an option in DS somehow, to apply to the mildrag?
do i need the rte encoder or something?
(it's not for a freebie, hoping to sell it to the daz store) :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,484
    I have re uv mapped stuff inc genesis and imported the obj as a uv
    likewise morph loader objects
    saving the figure as a support asset creates the uv files and morph files too
    my genesis has those uv's and morphs as a result so I guess the dsf file in the uv folder does it
    I think you need to redistribute it through Daz as you said though.
    does mildrag need to be in a native ds format first?
    thanks
    probably
    I only did triax stuff and objects so it may not be possible that way
    One, I'm not sure what you are trying to do but
    UVmapper Classic is good simple basic tool for simple basic types of uv mapping needs.
    If you are planning on remapping or otherwise altering the UV map of original MilDragon, you will need a more advanced UV mapper.
    At the very least you will need UV mapper Professional. A better choice might be Headus UVLayout or Right Hemisphere's DeepUV.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    DS doesn't read a .uvs file, you need the remapped OBJ file. You also need to keep the same material zones - the UV Set is a material setting, so you can't change the actual zones themselves. Edit>Figure>Geometry>Load UV Set... will let you load the remapped OBJ.
    does Daz already haz someone working on a mildrag 3 yet?
  • scathascatha Posts: 756
    Or better yet, the SubDragon 2.
    Or even better still, Adult Hatchling Dragon 2.
    hard to remember which ling uses which uv map.
    hatchling plus = mildrag2
    hmm filtered on ling, hoping it nabbed everybody
    Hatchling Dragon
    Hatchling Dragon PLUS!
    Hatchling Phoenix Poses
    Millennium Dragon 2 Hatchling
    Sea Hatchling
    SS Hatchling Maps 2
    Toonimal: Hatchling Phoenix
    Underworld Realms Playset 1 - Falling Bri
