3Delight message #143 (Severity 2): D2004: failed to open display driver
Hello everyone.
I had to reinstall the system on my PC. Installed Daz 4.12/ And encountered some issue with rendering. I get this message in render process window:
3Delight message #143 (Severity 2): D2004: failed to open display driver 'C:/Program Files/DAZ 3D/DAZStudio4/displays/png.dpy' (display driver returned '4')
As a result I can't render outlines in LineRender9000 by Scripted 3Delight. Daz just doesn't create needed files. I tried defferent versions of graphic card driver. It changed nothing.
What security software are you using?
Windows defender.
That doesn't usually cause issues. I thought this had come up before but a search isn't finding it.
I tried Daz 4.10 - same problem. Reinstalled Windows again - it became even worse. Someone> help me please. I'm in dispair.
Does someone know at least what is C:/Program Files/DAZ 3D/DAZStudio4/displays/png.dpy file?
Hi
That file is used by 3Delight to create PNG files. If you can do a normal 3Delight render, that will confirm it's just an installation/configuration problem with LineRender9000.
Thank you! Yes default 3Delight renders are fine. I will look into LR9K then!
