How to fresh re install G2F?
BobvanBobvan Posts: 2,653
Through errors and duplications as mentioned on several occasions my G2F takes over 10m minutes to load and is impossible to merge onto large scenes. What is the best way to purge and re install manually? Is there a trouble shooting clean up option or files to remove and re install? I manually install by unzipping files into My Library...
Post edited by Bobvan on
  • It isn't the base you wold need to reinstall but the additional morphs that need pruning - ideally by uninstalling, though you can just edit the /data/daz 3d/genesis 2/ female/morphs folder (from memory, and assuming you use DIM or manual unzipping to install).
    Don't install manually use DIM, just be sure to run it first in off-line mode so that you can set your preferences.
  • BobvanBobvan Posts: 2,653
    edited October 2019
    It was installed manualy. How do I know which morphs cause the issue log file?
  • It may be two morphs, but the log file will list the second (I think). Soemtimes not, sometimes it will be an error in a single file, but that should be rare as it would be caught in testing.
    Found and removed the evil little buggers now loads in 45 seconds vs 12 minutes..
