Mimic Pro
Mosk the ScribeMosk the Scribe Posts: 908
DIM didn't install Mimic Pro. When I went into my content to install it manually, it says Inactive next to Mimic 3.1 Pro.
Is that because it's only 32 bits and I just have DAZ 64 bit version installed?
Or was only compatible with DAZ 3.x and I'm running 4.6Pro?
Can I simply install Mimic Pro anyway and just drag the pz2 files onto characters in DAZ 4.6?
Or do I need to install DAZ 3.x if I can find that - and would I let DIM do that or do it manually?
Thanks for any help.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,803
    not all stuff is in DIM
    you can still install it from the zip unzipped
    works in DS4 drag and drop like 3
  • Mosk the ScribeMosk the Scribe Posts: 908
    Don't see a dmc file for M4 - also none for the Kids 4 (which I don't think I had on my last computer either - just used m4's)
    Are these dmc's available somewhere or do I have to try to find them on my old computer?
    Thanks
    should be under plugins if you have mimic
    V4 works on M4 and K4
  • Arnold CArnold C Posts: 740
    Thanks
    DS 4.6 64-bit doesn't have the dmc's included unless you own and had installed the Mimic Live! plugin.
    In that case you can find them in your DS base installation ( normally "C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzmimic\Configuration_Files").
    However, you can still find them in the DS 4.6 32-bit installation which can be installed side by side with the 64-bit one. Mandatory if you plan to LipSync within DAZ Studio for this plugin is 32-bit only! Normally located under "C:\Program Files (x86)\DAZ 3D\DAZStudio4\plugins\dzmimic\Configuration_Files".
