measure metrics wont install
BAM! Renders
ok for some odd reason i can not get my measure metrics to find the path where my daz software is installed, it keeps giving me the error "can not find daz install path" and then shuts off the installer. does anyone know the fix to this?
Are you installing using the same method (DIM or stand-alone) as you used for the base applciation? Does the version you are installing (32/64 but, General Release or Public Build) match the vesion(s) of DS you have installed?
ive tried DIM and manual and both do the same thing. I'm using 64 bit DAZ. I made it work before but I cant remember what the fix was that I did.
Funny thing is also the Measure Metrics doesnt show up in my DIM. The figure metrics does but not measure metrics.
For some reason its not seeing the installation path to my D: Drive where Daz is installed at.
Edit: Ok even switching installation to C: Drive is even doing it. I'm starting to think measure metrics is not working right or something cause it shouldnt be doing this.
How was Daz Studio installed?
well i tried to install it on D drive and i always use DIM to install it. That didnt work so I tried C Drive and that also didnt work. Both times were installed through DIM.
EDIT: It was a problem with choosing a directory in DIM. When I installed Daz Studio manually, and then installed Measure Metrics, it installed fine. Don't know why DIM is confusing Measure Metrics to install to the right location.
