DMC files in DIM after update..what are they?
KharmaKharma Posts: 3,214
I had 2 new update files in my DIM the other day, one is Genesis 2- DMC and the other is Toonimal Lemur-DMC. Can anyone tell me what the DMC refers to .. I haven't seen this mentioned in the forums.
    It is a small file, but I assumed gen 2 dmc was some sort of update to gen 2 starter essentials. Perhaps some minor code since its only 3 kb.
  • KharmaKharma Posts: 3,214
    Investigating further I think it has something to do with mimic? which I don't use or have.
  • DZ_jaredDZ_jared Posts: 1,316
    DMC stands for DAZ Mimic Configuration. It is the file that allows mimic to know which morphs are associated with which phonemes. Essentially it allows you to do lipsyncing in Mimic. However mimic 3 currently only supports .cr2 files, not .duf files.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    It can also be used in lipsync in DS4 32bit & mimic live in the 64bit
    also the carrara 8.5 mimic plugin
    I created a .dmc file for genesis2 from the default file for myself that I put on sharecg as Daz had not at that time supplied one and others had asked.
    Now that has been rectified it appears.
