Question about Yeti Hair
Charlie Judge
What hair does the new Yeti HD use? Will it work in DS4.10? That is -- Is it dForce hair and therefore require DS 4.11 or is it some other type like modeled or fibermesh that can be used in DS 4.10?
Post edited by Charlie Judge on
The promo images all have the dForce logo on them, so between that and the general look of the hair, I'm going to guess that it's dForce hair, and thus would require an upgrade.
I'd tell you if DIM would not keep failing the download on me.
It's dForce Hair. It really is so much easier to work with, and the Yeti is worth it for the sculpt alone.
- Greg
DIM won't install for me, either. I downloaded the file manually into the DIM folder, and reboot DIM. It still thinks it needs to download it, and won't install it.
So I just manually installed for now. I'm not waiting on Tech Support to figure out why DIM is working for some and not for others. Intermittent issues are so hard to find and fix. (I say "intermittent" because obviously some of us are able to download and install.)
