Predatron Goblin Cleric
Dear,
I'm playing with Predatron Goblin Cleric: https://www.daz3d.com/goblin-cleric
Some content are in "smart Content" tab and other content are in "Content Library" tab.
I have found almost everything I need except:
- the different materials for robes, color and/or dirty, see the 1st attached image.
- the ears cross the hood, see the 2nd attached image
Where can I change or resolve this issues ?
Thanks a lot, Xavi
500 x 650 - 124K
1219 x 1004 - 243K
  • NorthOf45NorthOf45 Posts: 5,898
    The different materials are in the Content Library, in the Poser Formats section under Poses/P3DA_GoblinCleric. You can locate assets in DIM by selecting the product and using the right-click -> Show Installed Files... You can see the full path of all the files that were installed. Or, you can browse the product archive to find it much the same way.
    About the ears, you actually have a choice. You can make the hood fit over the ears, or hide the ears. Select the Robes hood, or the Goblin Cleric head, and look for the approriate morph in the Parameters tab.
    I'm surprised that you have Smart Content for the Goblin Cleric, it has no metadata, unless you added it. The base Goblin figure has metadata, but nothing you are looking for is in there.
  • xavieratorxavierator Posts: 161
    edited September 2019
    Perfect, robes materials found
    Perfect, ears hide, the slider is "Ears Gone"
    Thanks and kind regards, Xavi
    Post edited by xavierator on
