Daz 3D CMS error help
ivansolovkovivansolovkov Posts: 22
edited September 2019 in Daz Studio Discussion
Hello, for some time i was using DAZ Studio just fine on my Win 10 PC.
When, suddenly...
problem like this appears:
https://helpdaz.zendesk.com/hc/en-us/articles/207812393-PostgreSQL-Connection-Error-and-No-Smart-Content
Probably i was done not very clever thing and just uninstal everething, to try fix things.
From this moment i can't install Daz3D and PostgreSQL neither.
DIM give's me...
...time after time.
What log shows:
OS bits: 64
Platform bits: 64
Qt Version: 4.8.7
Locale: ru_RU
Running on Windows 10, Build 9200, No Service Pack Installed
Physical Memory:
Total: 19.9 GB (21438021632)
Avail: 15.3 GB (16483483648)
Virtual Memory:
Total: 127.9 TB (140737488224256)
Avail: 127.9 TB (140732945481728)
Current Memory Usage: 23%
Current DateTime:
Loc: Сб 28. сен 15:01:38 2019
UTC: Сб 28. сен 12:01:38 2019
Application Data:
Location = C:/Users/IvanS/AppData/Roaming/DAZ 3D/InstallManager
Disk Total: 231.8 GB (248907395072)
Disk Avail: 99.1 GB (106452336640)
Reading dzInstall.ini
Cannot locate dzInstall.ini
Current Account: Account
Current Download Path:
Location = C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads
Current Content Install Path:
Location = C:/Users/Public/Documents/My DAZ 3D Library
Disk Total: 465.7 GB (500100493312)
Disk Avail: 114.6 GB (123077554176)
Current 64-bit Software Install Path:
Location = C:/Program Files
Current 32-bit Software Install Path:
Location = C:/Program Files (x86)
Starting CMS...
WARNING: dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
Make sure the server address and port number are correct.
Error connecting to CMS. Cannot be started by client.
Product 42071-3:Genesis 8 Starter Essentials Mimic has no tags
Product 16281-2:Victoria 6 PoserCF has no tags
Processed 38 products with 93 unique product downloads
Saving Account Settings: Account
Installing product : PostgreSQL CMS (Win 64-bit)
WARNING: Killed Process
WARNING: QProcess: Destroyed while process is still running.
Product installation failed : PostgreSQL CMS (Win 64-bit)
Install Queue finished in 1 min 1.8 sec.
What i tryed:
Deinstall and clean anything i can found about DAZ and CMS including clean up AppData and registry check with CCleaner.
Install all manually.
Change ports in CMS settings.
Make custom exception for Firewall.
Post edited by ivansolovkov on
  • And does it always fail to find the account.ini file? That suggests a permissions issue - have you, in the past, run Instal Manager "as administrator"? That is, right-clicked adn selected Run as Administrator - running normally from an admin account is not a problem.
  • ivansolovkovivansolovkov Posts: 22
    To be honest, i don't know. Never look at this thing before.
    But, my Windows profile is already have administration status.
    If i will try to start DIM as Administrator, i got this:
  • As I said, running normally (not picking "Run as Administrator") from an administrator account is not a problem - meaning explicitly running as administrator, in the past, was; the ability to do so has now been blocked. If you go to
    %AppData%/daz 3d/InstallManager/UserAccounts/
    (just paste that into the address line of a file browser) can you see an Account.ini file? If you double-click to open it (it shoudl oepn a a text file in your default text editor) do you get a UAC prompt to allow it? If it does open does it have any content?
    Yes, account.ini in place. Can open it just fine.
    Yes, it have content inside with most of my current DIM settings.
  • Then I don't know what the issue is - I think you need to open a Technical Support ticket, sorry (make sure you click the Sign In button at top-right if it isn't shwoing your name, otherwise you will have to enter your details and complete a captcha). https://www.daz3d.com/help/help-contact-us
    https://i.imgur.com/A1Dg7Bx.png Are you sure that this people will able to help me?
  • So, Daz support was useles. They even do not responde to me anymore.
