Face Transfer failed to load base material
My 3D Spin
in New Users
I am starting to learn how to use the Face Transfer in the new DAZ 4.12
before i buy it.
Everything works fine but i keep getting this message:
Face Transfer failed to load the base material preset.
The image will transfer but with reduced quality!
Anybody knows why?
I suspect you'll get more help if you ask this question in the official 4.12 thread here. And you may find some useful information in this Art Studio thread, is there a Face Transfer thread.
I haven't done anything with Face Transfer myself, so I have no first-hand knowledge to help you with.
Maybe he has something to do with this message i first got when i
dident have a G8 loaded and selected!
Did you Update Genesis 8 Starter Essentials
Make sure you have the updated vesion of Genesis 8 Starter Essentials installed.
I get this error message too and there's a hint in the logs:
I think Face Transfer is sending a bad filename to the content manager. It might be a bug, because it happens every time I use it.
But the log doesn't tell us "what" filename it's sending. Probably one that doesn't exist.
Have you installed the updated Genesis 8 Starter Essentials? If so, through DIM of Connect?
I installed the starter essentials a long time ago. Is there new content related to Face Transfer in the essentials package now? I haven't done that.
I downloaded both male and female starter essentials, installed them, and the error went away. This looks like the missing file that didn't exist in the old essential package:
Yes, the update adds a clothed figure (which is what you get if you run it without having a Genesis 8 selected) and the files required for the materials at least.
Same issue!!!!!!! will they give us an fix. Were pauing
Hi
I'm getting the same face transfer issue, missing new content and an eye problem
Following missing new content
I reinstalled all the Daz content to a different directory H:\ My DAZ 3D Library using the Content |Manager and Renderosity Poser content to it's now fixed location public folder C:/Users/Public/Documents/My DAZ 3D Library usning Win Zip
New content issue resolved. I assume that the Daz3d Poser content also goes to this Public Directory
Face transfer issue
Downloaded Genesis Genesis 2, 3 and 8 Genesis 8 Starter Essentials from Daz 3d site installed, no change still same problem
Since the reinstall to fix the content problem the face transfer no longer generates a clothed Genesi 8 figure
With nothing loaded in Scene, I get Face Transfer failed to load Genesis 8 figure Could not locate the female Genesis 8 file
"data/Daz 3d/Genesis 8 Female Starter Essentials/utilities/Genesis 8 Female With Basic Wear .duf using photo
With Genesis 8 Female loaded, Face Transfer failed to load the base material preset
The Image will still transfer but with reduced quality
I was wondering when updates are provided in the Daz Installer from time to time they are different to the ones I download?
Eye Problem
Created new face transfer then made Generation 8 figure move
Noticed eyes were popping out of Generation 8 figures head, seems worse when eyes were set to follow camera?
Using Key mate, I can't see any keys to move the eyes
This doesnt seem to happen with a standard Genesis 8 figure
I aslo rebuilt the database and reimported the Meta data still no change
Perhaps Smart content isnt seeing the Gen 8 folder
OK so I've noticed that the daz 3d folder is in 2 locations
In my case ive put the daz content onto my H drive
in a folder called H:/ My DAZ 3D Library
inside this I can see this a folder called data
inside that a folder called / daz 3d
inside that just genesis genesis 2,3 and 8 nothing else
I also can see this in the content folder
Data / DAZ 3D / but this has the female started folders in as well
I've copied these starter folders to folder above H:/ My DAZ 3D Library
and it now loads the Genesis figure with basic clothes, I haven't copied the Genesis ,Genesis2, 3, and 8 across yet
I've now copied the Genesis, Genesis 2, 3 and 8 folders from the Content/Data /Daz 3d to the Data/Daz3d and all is now working OK no errors
OK
I ahve remved all Starter Essentials (Except Mimic) and downloaded fresh and reinstalled ALL of them again and I still get this missing error. Is there ANY help at all or are we just out here with our pants down? I have NO desire to be moving my content files around and such.
The required mat then should be found on whichever Drive at:
:\DazDocs\DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis 8\Female\Tools\Presets\Genesis 8 Females Simple MAT.duf
Sometimes rebooting the computer helps D/S reregister [or whatever it does] all what it has.
You ROCK! Thanks a bunch even though my initial spelling was horendes. I actually had to add in both male and female but is not getting errors now.
Thanks
You're quite welcome, glad you got it working! Enjoy.
btw - if you find that you want the face morphs um, 'fuller', this product was an instant buy for many of us when it came out:
https://www.daz3d.com/face-transfer-shapes-for-genesis-8
It was designed to compliment the Face Transfer plugin.
