warning problem running post-install step
zeftoonyzeftoony Posts: 0
Hi,
i get this error message when i try to install
Glute and Breast Movement for Genesis
V4 and M4 Shapes for Genesis
Fujian Tulou Fortress
and many others of the same installation type
warning problem running post-install step. installation may not complete correctly Error writing file
C:/RunFirst/Process Newly Installed Content.txt
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Try downloading the current zip version and either unpacking manually or using the DAZ Install Manager to install. I suspect that's just the CMS setup that's failing, placing the file that runs the next time DS starts, though the path looks wrong.
  • matthieu.dalomatthieu.dalo Posts: 8
    Hello ! I have the same problem ! What can i do ? :s
  • Testing6790Testing6790 Posts: 1,091
    Hi all! Veteran of manual installation of content here! If you're doing what Richard suggests be sure to move the contents of the "Content" folder into your library, don't put the actual "Content" folder in it!
    Also, when manually installing content, you will need to re-import your metadata if you want it to show up in your Smart Content area.
  • frank0314frank0314 Posts: 15,098
    Are you trying to install it manually or with DIM. If manually is it a zip or an installer
    Manually and it's a Daz3D Studio installer ! :/
    edited April 2014
    Go to your product library and download the current zip and install that. Installers were done away with for content
    Post edited by frank0314 on
    I just have the daz instaler :/ I can't go to my product library !
  • scorpioscorpio Posts: 8,533
    The Product library in your account here at Daz, from there you can download the zip.
    Ok !! Thanks a lot ! :)
