Ccannot use DAZ 3D Studio 4.12
I am unable to login, and forced to load the studio offline, but then I am unable to do anything. I can load up a figure, but then cannot turn them or do anything with them. It seems I must be logged in to use the software, but cannot login.
  • LeanaLeana Posts: 13,276
    You don't need to be logged in to use DS, I never used the login feature and it works fine for me.
    What kind of display option do you use for the viewport?
  • I have the same login problem, although I can log in here on the site, DAZ Studio does not accept the login data and tells me that the server does not recognize the data.
    In offline mode, I can load two figures, but now the biggest problem, the IRAY Render does not exist, only Open GL and 3D Light.
    In the beta tested, everything was not working, and I urgently need to finish my comics. Would be nice if you fix this as fast as possible. BTW. in the DIM, I'm not synonymous with login.
    Nothing to do with using it or not, it should work.
    I have the same problem. Login problems, slow daz website etc. Where is the news flash? There must be some serious technical problems at their servers.
    Studio 4.12.0.86 works fine. As did 4.11 and the 4.12 Beta.
