PP2 , PZ3 show sliders in Studio but don't morph - Solved
nowefgnowefg Posts: 557
I have prop, a pp2, that won't morph in Studio 4.6, (or in 4.5 for that matter,) although the morph sliders shows up.
I tried loading it into Poser 9, and saving it as a pz3, which once solved a similar problem for me, but, again, importing that pz3, I get the unmorphed prop, and the slider that doesn't work.
Is there a way, via Poser or in Studio 4.6 alone, that I can get this morphing pp2, to function in 4.6?
Post edited by nowefg on
  • Richard HaseltineRichard Haseltine Posts: 111,701
    Before saving from Poser make sure that in edit>General preferences>Miscellaneous you have use External Binary Morph targets unchecked.
  • nowefgnowefg Posts: 557
    edited January 2014
    Thank you.
    I thought I did, but I'll double check.
    Update: It wasn't checked, but following the procedure worked. The prop works perfectly, now. Thank you, Richard.
