Duplicate ID problem
KaribouKaribou Posts: 1,325
edited January 2014 in The Commons
For some reason, I am getting duplicate ID errors on all of my Genesis 2 Female characters. I've downloaded and re-installed all of the latest starter essentials reinstalled DS. Twice. I also reinstalled DS. I thought you weren't supposed to get duplicate IDs with duf files...? Any advice?
Post edited by Karibou on
  • Richard HaseltineRichard Haseltine Posts: 111,992
    I suspect it's a third-party morph. If you open the log file (Help>Troubleshooting>View log) after loading G2F and scroll to the end you should be able to find the names of the offending morph(s) (there will also, in all probability, be messages about being unable to find properties - those are harmless).
  • KaribouKaribou Posts: 1,325
    Found it! The log showed the morph. Opened it in word pad and there was a missing "-1" at the end of the file. All better!! Thanks!
  • nowefgnowefg Posts: 557
    I've been having the same problem, and will check the log, but have a couple of questions:
    How can there be third party morphs already activating when I first load the Daz3d G2F figure?
    Shouldn't those third-party morphs need to be specifically applied by the user AFTER the original figure is loaded?
    Also, what does the "-1" signify and how did you know to fix it? I'm going to look at mine, but wonder about recognizing the culprit missing piece.
    With TriAx figures like the Genesis series the morphs are always available, they don't have to be injected, and the basic set-up is loaded with the figure (the actual shape isn't loaded until needed, however, to save on memory).
