Environment finite sphere radius
What's the radius of the finte sphere in the environment render settings?
  • FishtalesFishtales Posts: 6,228
    It's in Metres I think.
  • DS uses cm as units, so that should be the unit (if it's a unit not a scale) here
    From the Documents.
    Dome Radius - Adjusts the distance between the center of the dome and the surface of the sphere-shaped finite dome; the size of the dome within “dome space.” For example, a Dome Scale Multiplier of 100 with a Dome Radius of 1 yields a dome that is 1m between its center and its surface, or 2m in diameter.
