Export user data 930 (30 minute!)
cm152335cm152335 Posts: 421
edited January 2014 in Daz Studio Discussion
I remember before, the use of "Export user data" in DB maintenance was fast
- Just some second after click
Now with minor changes it takes more than 30 minutes!!
- Same if I want to re import user data!
Does that happened to any other user or I am the only?
problem start in two last Daz updates version.
Post edited by cm152335 on
  • SylvanSylvan Posts: 2,719
    It can indeed take up some time.
    Probably you had lessitems back then and that would explain the added time now.
  • fixmypcmikefixmypcmike Posts: 19,739
    It's always taken 30-45 minutes for me, ever since they introduced the feature in DS4.5.
  • cm152335cm152335 Posts: 421
    I think is introduced long time before 4.5!
    Since I "export user data" is more than a year, if my memory doesn't fail!
    No, I'm pretty sure it was introduced with 4.5, which was a year and a half ago, I think.
    One idea ... if you've had the same content database for a long time, the indexes and data tables inside the database could be fragmented (this is different than the file being fragmented on the hard drive). As I recall, there is an option from the DB Maintenance menu to compact the database. This should correct any fragmentation issues as well.
    Being the "belt and suspenders" type guy that I am with these things, I might copy the content database files off somewhere before you do this, though. Just to be safe. :)
