Help with RSSY Clothing Converter from M4 to G8Male
AlricAlric Posts: 220
I was hoping to use "RSSY Clothing Converter from Michael 4 to Genesis 8 Male" to convert some old Xurge3D clothing items to G8. Unfortunetly I've run into a small problem. It looks like the script is adding breasts to the clothing items. All the other body parts like lower body (pants), boots, gloves, and helmets are working fine. The problem is the chest area is ballooning out away from the figure.
I double checked and it is, as far as I can tell the M4 to G8M script. I don't own the V4 to G8F script.
I tried converting the item as a coat and as a normal bodysuit both had the same result.
I know conversions are never going to be perfect, but I was hoping for a little better fit.
==Edit===
Nevermind.
I was trying to avoid installing Michael 4 since I don't use him. I went ahead and installed him and tried the outfit on him and it fits the same way so the converter is working perfectly fine.
566 x 1244 - 136K
569 x 1253 - 134K
Post edited by Alric on
