From Several Objects Down to One
To set the stage for my question, I created three in Hexagon and imported them to DAZ3D. For the purpose of my question, let's call them Head, Handle and Grip (imagine a hammer).
Once in DAZ, I have three items in my scene - Head, Handle and Grip.
I've parented head to handle, and handle+head to grip. So, in the scene I can collapse grip and whereever I move grip, or rotate it, resize it, etc., the other two follow. And, if I go to surfaces I can select each one and change the texture on each one.
What I WANT to do is turn these three in to one item in the scene, but if I select that item in the surfaces tab, I see all three surfaces. Thus, in the Scene tab I do not want the user to be able to expand it. It will simply be ONE object, but with three textures.
How do I do this?
You can do that in Hexagon itself. It's a common misconception with new modelers that an OBJ file has to be a single mesh. It doesn't. You can model all those parts individually and put them together and export as a single object.
I would do this...
Hi JonnyRay,
I must be missing something. When I do that, I end up with three items in my scene tab in DAZ, and that's what I'm trying to get away from.
Is there another step in Hexagon that I'm missing? Or, is there an option I'm missing when I export the .obj?
Brent
Simply export from Stuio as wavefront object then import back in.
That doesn't accomplish what I'm looking for.
You need to use the Geometry Editor tool to rename the surfaces, then export to OBJ and erimport as jestmart described.
