Any outfit like this for Daz?
Hey guys. Is there any outfit in the store (or elsewhere) that is similar to this? I have Genesis 1 2 3 and 8. Also sorry if this is the wrong section, I was confused between this and Product Suggestions
364 x 628 - 98K
400 x 600 - 40K
  • GordigGordig Posts: 10,802
    Super Bodysuit is a good place to start. There are tons of outfits in the store that would work, depending on how much work you're willing to put into it.
  • Exnem probably has a few like that at Rendo.
    Let me look through my library...
    Sci Fi Spy... https://www.daz3d.com/sci-fi-spy-outfit-for-genesis-8-females
    Strike Back, maybe... https://www.daz3d.com/strike-back-outfit-for-genesis-8-female-s
    Bounty Huntress, also maybe... https://www.daz3d.com/bounty-huntress-outfit-for-genesis-8-females
    Hmmm. So if I get this and the texture pack for the green, I should be able to make this? Not sure what you mean by the last line.
    Wow all of these are pretty similar. I think if I could mix and match features from these it would be very close lol
    Looking through the store a little more, Helix Alpha and Ribbed Superhero Suit look a lot like her outfit except for the legs. You could get away with Helix Alpha if you used really tall boots.
    edited September 2019
    What I mean is that there are adjustments you can make, like opacity maps to alter the cut of the top, for example, or bump/normal maps to simulate the lines in her outfit. It all depends on how close is close enough. For example, here's the Super Bodysuit and the holsters/belt from ArtemisX. I was super lazy with this; I just killed the base maps and roughly eyeballed the colors, but if this look would suffice for you, it wouldn't take a whole lot of work to make it look way better.
    1800 x 2400 - 3M
    Post edited by Gordig on
    Wow that looks super good. I am new to Daz/3D and not familiar with those terms but I will get that item and mess around with the settings till I get it similar to yours. Thank you!
    Here's what I did:
    1) Load the Super Bodysuit onto your character.
    2) Select the Bodysuit, then add the Gloves 1, Shirt-Sleeve1 and Shirt-Neck1 attachments in the Wardrobe pane of the Bodysuit.
    3) With the Bodysuit still selected, open the Surfaces pane and select all the surfaces, or click on the "All" at the top of the pane. Click on the square next to the Base Color parameter, and select "none". The suit will now be white. You can then either click and drag the numbers in the base color box to play around with red, green and blue, or click inside the box to bring up the color selection dialogue. The color settings I used for the suit are Red 24, Green 92, Blue 0.
    4) Follow the same steps with the boots and belt, except using Red 56, Green 134, Blue 7.
    Like I said, I was really lazy setting it all up, so if you need more detail, like trim on the holsters for example, you can edit individual surfaces instead of everything at once, you can create additional maps, you can do all sorts of things. This will get you started, though.
    1773 x 854 - 710K
    1187 x 876 - 202K
  • Gordig said:
    Here's what I did:
    Thank you so much for the detailed tutorial!! I would have been stuck on step 3-4 for a loong time. And this is something I can use for other clothes as well so very helpful :)
    Now I'll just go look for similar hair, for which I think there will be a lot of options
