keeping more then 1 Deltas morph to V4/M4
assmonkeyassmonkey Posts: 0
so I'm trying to figure it out...nothing yet
Seems whenever I do click another deltas morph inject, it replaces the one from before
    If they use the same morph channels, the new values replace the old. Do you know if these morphs use the legacy "community" channels or ExP morphs?
  • assmonkeyassmonkey Posts: 0
    I don't know
    I copy, pasted them in to my folder
    their like this
    Hide.Valeria.pz2
    InjDeltas.Valeria.pz2
    And what is the other morph that is overwriting it? Or does it seem to happen with any other morph?
    What I'm trying to do is apply these morphs, so I can save the V4 & M4 figures as the form of what the Genesis figures are
    Do you mean convert to Triax? Or apply a shape to make them look like default Genesis?
    I want to convert it
    Do you inject all the morphs before converting to triax? What is the exact problem you have after converting to triax?
    I know that's what you do
    but it would sort of be a problem if injects are being replaced, unless there is a way to save these morphs in that Data format
    That shouldn't be a problem for ExP morphs, but is a potential problem with morphs using the community channels. Are there other morphs you know are causing problems, or is this hypothetical?
    I got a bunch of morphs made by 1 person (free), so those are causing an issue, since when I load 1, the other goes away
