what happens to auto follow when a clothes has a support morph?
does ds detect it and cancel the following?
for example if a skirt has an Aiko 8 support morph, then autofollow knows not to kick in?
or is it up to the creator to cancel autofollow in the skirt for aiko 8?
    when i buy a Genesis 8 character, like Vladimir 8, does he bring in support morphs for the anatomicals, like the eyebrows, and the other anatomicals?
    when creating a support morph for Victoria 8,  do you include the scaling in the morph deltas?
    or do you add the scaling separate?  if so, how do you copy scaling to the skirt?
  • LeanaLeana Posts: 13,501
    If the support morph has been saved with the same internal name as the autofollow morph then it replaces it, and will be applied automatically instead of the autogenerated one.
    If it has been saved with a completely different morph name then it will be considered as an independant morph, so autofollow will create an autogenerated morph too.
    It depends on the character and whether or not it would require a custom support morph.
    As a rule it’s better not to include scaling in a morph. If the original character uses a combination of scaling and morph then the support morph needs to be created for the unscaled version.
    Thanks.
    think its called Aiko8FBM.
    it doesn't look like the eyebrows or eye lashes has any support morphs.
    That probably means that auto follow works well enough not to need a custom morph.
    Aiko8 really starting to grow on me.  Is the first 8 character i feel like rendering
    making her work in carrara is a project and a half.  but ... not impossible.
    did a girl 8 ever come out?
    Leana said:
    Thank you.
    i missed that one.
